Latest: morgan20
Overall: 17135
Online Now [496]:
Visitors: 495
Today: 67151
Total: 110619148
Forums › The Car › 206 Problems › wishbone matching
wishbone matching
Sim
PostPosted: Sat Jan 19, 2013 6:18 am Up
Hello,
I'm replacing N/S wishbone as its balljoint gater got ripped (MOT due)
Found a replacement from a broken "2004 2.0 GTi", meanwhile mine's "2000 2.0 HDi". Is it OK to go ahead and have to different wishbones?
Cheers,
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Sat Jan 19, 2013 6:41 am Up
It's just not worth fitting second hand wishbones but yes all wishbones fit all 206 models. Only difference is Sports range cars use a metal bush instead of a rubber bush in the wishbones.
PostPosted: Sat Jan 19, 2013 10:20 am Up
2nd hand wishbone FFS Rolling Eyes
DanT
PostPosted: Sat Jan 19, 2013 10:30 am Up
Just...don't do it! Not worth it.
Buy a new one.
PostPosted: Sat Jan 19, 2013 10:40 am Up
£67 for a decent branded new wishbone from Euro Car Parts. Mad to not buy a new one.
PostPosted: Sat Jan 19, 2013 10:59 am Up
I've got some slightly used toilet roll here if you want to buy that too. It's still got a good few wipes on it. It's Andrex Touch of Luxury with Shea Butter. Retails new at 56p a roll, I'll do it to you for 20p.
DanT
PostPosted: Sat Jan 19, 2013 1:20 pm Up
Personally i always replace in pairs, ie drop links, shocks, top mounts, wishbones etc but i realise your average person is not too fussed and wants it done as cheap as possible.
That said, as mentioned above, you can buy a decent brand new one for around 60-70 quid.
It will cost you a lot more than that if your second hand one fails!
PostPosted: Sat Jan 19, 2013 2:35 pm Up
To save a lot of work with care you could just remove the spring clips holding the rubber cover on the ball joint and switch them over. Clean out your old ball joint, re-grease with black moly grease and fit the new cover. I think Peugeot even list the boot as a separate part.
Me? I would buy a complete arm or pair from here. Klarius is in fact QH. In 35 years I have never had a problem with QH parts.
www.buypartsby.co.uk/b...trol-arms/
£37.44 each so good price to.
Second hand arms with any play or wear in your ball joint and the money you save is quickly lost in excessive tyre wear - don't do it.
Finally after the arms are fitted you will need the tracking checked.
Sim
PostPosted: Sun Jan 20, 2013 8:34 am Up
Thanks for insightful replies
Rubber cover got split in a local garage by a rookie mechanic. I noticed it when it was too late to blame.
Surely want to done this cheap, because the joint itself is not worn (apart from driving with split gater) and it's a waste to replace good O/S wishbone too yet.
Will look for rubber housing for balljoint if i get lucky to find it sold separately
Cheers
EV
GTC VXR (sold)
Sim
PostPosted: Tue Jan 22, 2013 6:09 am Up
Here you can buy just ball-joint boots with clips from this awesome seller, make sure you measure first ofc:
www.ebay.co.uk/itm/2-X...27cee350d5
EV
GTC VXR (sold)
PostPosted: Tue Jan 22, 2013 6:28 am Up
You'll also need clips for those boots. Good luck with these though, i'd also check the inside bushs.
Sim
PostPosted: Tue Jan 22, 2013 6:47 am Up
"All our kits are supplied with the appropriate number of steel clips as fitted to many vehicles from new."
Or you meant some other ones?
EV
GTC VXR (sold)
PostPosted: Tue Jan 22, 2013 7:48 am Up
That's the ones! You no you need to grease the insides as well.
PostPosted: Tue Jan 22, 2013 8:00 am Up
Those clips are a pain to put in place.
PostPosted: Tue Jan 22, 2013 2:56 pm Up
Yes they can be. Quite easy to tear the new boot if you aren't careful.
