Online Now [664]:
Visitors: 663
Today: 100888
Total: 145579923
Forums › The Car › 206 Problems › Traction control ESP not working
Jammie_1989
PostPosted: Sun Jan 20, 2013 3:23 pm Up
I fitted a new stereo and to make the stereo come on with the ignition I cut the ignition wire and linked it into the power. Big mistake Sad I think the wiring diagram I had was probably wrong as although it worked as I intended I blew my ESP.
I have checked the fuses and they all seem fine however I don't have the manual to see which fuse it what. What do you think I have done as it just says not functioning all the time Sad
Car is a gti 180 btw
206 gti 180
PostPosted: Sun Jan 20, 2013 3:27 pm Up
Look in the forum FAQ as the fuse lists are posted in there.
Jammie_1989
PostPosted: Sun Jan 20, 2013 3:29 pm Up
Thanks I've just looked and when checking the fuses under the bonnet i've already looked at the one which is linked to esp fse 3 and its fine have also swapped it with another and still the same.
206 gti 180
PostPosted: Sun Jan 20, 2013 3:35 pm Up
Is that under bonnet or in car?
PostPosted: Sun Jan 20, 2013 3:36 pm Up
Have you disconnected the radio and put everything back as original?
Jammie_1989
PostPosted: Sun Jan 20, 2013 3:39 pm Up
Its under the bonnet and yeah i've put all the wiring back as it was. Also just been and rechecked with a new fuse and nothing Sad
206 gti 180
PostPosted: Sun Jan 20, 2013 4:22 pm Up
Do your getting the warning on screen about ASR/ESP DEACTIVATED. any abs lights? Might possibly need a code read?
Jammie_1989
PostPosted: Sun Jan 20, 2013 4:46 pm Up
Thanks for the reply I've just been out in the snow to look again and I've fixed it Smile Fuse no 6 had originally blown which I replaced but as it was still wired wrong i'm guessing its blown it again as was blown. The wiring has been fixed recently so put in a new fuse and its fine now Smile
206 gti 180
