Posted: Wed Jan 23, 2013 6:51 am |
is anybody else having problems with interior getting damp because of Heko wind deflectors messing with seals? it might not be this just trying to narrow down... they're all properly fitted as per instructions i just cant help but feel its letting damp in.
otherwise any other recognised problem areas? car is getting more and more damp and mouldy!
cheers in advance.
Posted: Wed Jan 23, 2013 6:56 am |
Are you sure its not down to the snow and crap on your shoes?
Posted: Wed Jan 23, 2013 7:01 am |
Also short runs never allow the interior to get warm and start drying...
Posted: Wed Jan 23, 2013 8:10 am |
iv had no trouble with my ones, i didnt use the little metal clip things they come with.
| Iv had:
Now : GTi 180 again - Build thread | |
Posted: Wed Jan 23, 2013 8:24 am |
I haven't had any problems with mine. If they are fitted properly without damaging seals etc then I would look elsewhere for the cause.
Posted: Wed Jan 23, 2013 10:25 am |
No issues with mine either, using the supplied clips!
Posted: Wed Jan 23, 2013 11:18 am |
Mine have been on the car for a while and haven't had a problem *Touch Wood*
