Forums › The Car › Solved 206 Problems › headlight beam adjustment on buckled lights - MOT fail? |
Posted: Tue Jan 22, 2013 7:12 pm |
Posted: Wed Jan 23, 2013 3:27 am |
Full beam won't matter, just low beam. It would be better to replace the headlights.
Posted: Wed Jan 23, 2013 1:29 pm |
Are you certain that the bulb is seated correctly. If you are getting the correct level at dip then the high beam should also be correct and not pointing into the sky.
A bulb incorrectly seated can give very strange beam patterns.
Posted: Wed Jan 23, 2013 1:33 pm |
| sledge wrote: |
But after the accident headlight units are still not fitted in an aligned fashion (looking at the front of the car in daylight it looks "cross-eyed")
Until you sort this issue out your just wasting your time.
Posted: Wed Jan 23, 2013 3:09 pm |
No time wasted, long time due MOT passed today (yes they ignored high beam), headlights replaced after the accident back in the day; I'll check the physical aim of high bulb, thanks for answers!
