Latest: Beduff1977
Overall: 17134
Online Now [75]:
Visitors: 74
Today: 34046
Total: 107346404
Forums › The Car › Solved 206 Problems › blower problem
blower problem
g24538539
PostPosted: Wed Jan 23, 2013 10:41 am Up
Can anyone help solve this problem . My wifes car heater would only work when on full then it gave up and died . After searching I found that the resistor switch has blown . I replaced it and it worked for an hour or so then stopped again . . I didn't replace the cabin filter . Could this cause the resistor to over heat or is it something more . ? Any help would be greatful . Thanks george.
PostPosted: Wed Jan 23, 2013 11:50 am Up
try to take the cabin filter out,because if it's blocked it can make the blower motor run with load,which can make it stop so that it don't get burnt.
