Posted: Fri Jan 25, 2013 5:33 am |
I just did a full service to my girls 2001 1.4 8v this week,all parts from ecp,including oil filter paper type,air filter,Bosch plugs,pollen filter,5litre 10w40 semi synth oil,5 litre red concentrate antifreeze,and engine flush for £49,this is online order only with 25% discount tho. Olly
Posted: Fri Jan 25, 2013 6:01 am |
I have purchased the parts from ECP now, got air, oil filter, bosch plugs and shell 10w40 semi synth oil. Hopefulyy going to get it down later
Posted: Mon Jan 28, 2013 1:22 am |
On my 2001 1.4 8v. the only oil that my motor factors say i should use for my car is 05-40 fully synth oil.
Posted: Mon Jan 28, 2013 2:03 am |
I wouldn't have gone for the red coolant or the engine flush...
Posted: Mon Jan 28, 2013 8:35 am |
bikesforme wrote: |
On my 2001 1.4 8v. the only oil that my motor factors say i should use for my car is 05-40 fully synth oil. |
A bit thin & fancy for a 8 valve TU lump, it should be ok but a 10w 40 semi synthetic would be better.
Posted: Mon Jan 28, 2013 8:37 am |
Edward wrote: |
I wouldn't have gone for the red coolant or the engine flush... |
Mines got DAF orange long life OAT coolant in it as that's what we have barrels full of at work
System was flushed last year when it had timing belt & water pump replaced.
Posted: Mon Jan 28, 2013 12:58 pm |
MrBSI wrote: |
bikesforme wrote: |
A bit thin & fancy for a 8 valve TU lump, it should be ok but a 10w 40 semi synthetic would be better. |
That's what i thought but that's the oil that is listed for the car at my motorfactors. Think i might use 10-40 semi next change.
Posted: Mon Jan 28, 2013 1:01 pm |
Edward wrote: |
I wouldn't have gone for the red coolant o[marq=right]r the engine flush... |
I always use red coolant and engine flush in my cars and never had a problem .
Posted: Mon Jan 28, 2013 6:24 pm |
Hay buddy,
Do you no were TFM is? (Rabbit run) I get my Morris's 10/40 semi 5ltr for £15 iirc and get a oil filter from Proislee motor spears usually around £3/4 ish I do that twice a year.
Posted: Tue Jan 29, 2013 7:26 am |
spike_202 wrote: |
Hay buddy,
Do you no were TFM is? (Rabbit run) I get my Morris's 10/40 semi 5ltr for £15 iirc and get a oil filter from Proislee motor spears usually around £3/4 ish I do that twice a year. |
cheers for heads up mate, £15 is a bargain price! will do the same next time
Posted: Tue Jan 29, 2013 9:03 am |
No probs mate in Bennets,Proislee motor spears and Livian autos all charge about £25 for the same stuff!
