Latest: tbafonso
Overall: 17130
Online Now [194]:
Visitors: 193
Today: 26079
Total: 103956435
Forums › The Car › Request a how-to › 1999 1.4 8v core plug behind camshaft pulley
Forum IndexRequest a how-to
mackem54
PostPosted: Fri Jan 25, 2013 5:23 am Reply with quote Up
hi there,
need some help, my core plug behind my camshaft pulley is leaking after car froze up,
was thinking of removing engine mount removing pulley and replacing,
just wanted to know if its safe this way as i dont want camshaft to move while doing it,
cheers
keep on to the end of the road
PostPosted: Fri Jan 25, 2013 10:46 am Reply with quote Up
If the car had the correct amount of antifreeze in it then it wouldn't have popped the core plug out during the cold weather IMHO Wink
PostPosted: Fri Jan 25, 2013 11:17 am Reply with quote Up
I got to the fourth line and gave up reading due to a lack of paragraphs.
mackem54
PostPosted: Fri Jan 25, 2013 6:05 pm Reply with quote Up
bump
  Quick Reply
Username:
Message:
Quote the last message
