Posted: Fri Jan 25, 2013 12:12 pm |
All my electric windows and sun roof work fine but the driver side window opens all the way but will not close all the way, I can't afford to get it fixed at a garage so is there any way I can temporarily force it shut just so I can use the car until I can afford to get it fixed? I tried pulling it up, jiggling it and pressing the button at te same time, any solutions?
Thanks,
O111e
Posted: Fri Jan 25, 2013 1:04 pm |
take the door card off and find out why its not shutting all the way!
Posted: Fri Jan 25, 2013 1:12 pm |
How do you get it off is it easy?
Posted: Fri Jan 25, 2013 1:27 pm |
Take the torx screw out of the little pocket on the door card (about half way up the door), and then unclip the card starting from the top and working down.
Or get a hammer and hit it very hard
Posted: Fri Jan 25, 2013 1:58 pm |
Hmm would a flat screwdriver work on a torx screw?
Posted: Fri Jan 25, 2013 2:18 pm |
O111e wrote: |
Hmm would a flat screwdriver work on a torx screw? |
Nope a torx is required to remove a torx screw
Posted: Fri Jan 25, 2013 2:28 pm |
iainlovatt wrote: |
O111e wrote: |
Nope a torx is required to remove a torx screw |
An angle grinder will remove a torx screw
Posted: Fri Jan 25, 2013 3:21 pm |
macca1411 wrote: |
iainlovatt wrote: |
O111e wrote: |
An angle grinder will remove a torx screw |
How would you remove the one in the door handle cup, muhaa
Posted: Sat Jan 26, 2013 1:31 pm |
Trade Rating: +45
A flat head does work in a Torx bit aslong as you get the right size, there is also a few more Torx screws round the edge if the door card including one under the tweeter cover.
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
