Online Now [303]:
Visitors: 302
Today: 54968
Total: 105948977
Forums › The Car › 206 Problems › Strange steering noise.
Tolkienfan001
PostPosted: Fri Jan 25, 2013 12:50 pm Up
Trade Rating: +13
Hi,
Just been out in the car and when turning full lock there is a strange noise from the engine bay. Happens only when turning right. And it is 1/2 to 3/4 of a turn before you hit full lock. The sound lasts only a second. It's not the same as the sound you get on full lock.
I have checked and the fluid level is correct and I have no leaks. It does it when parking at low speed or if the car is stood still and I go from lock to lock.
It has only started doing it this evening. Could it be the cold weather it's 1c here?
Any ideas?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Fri Jan 25, 2013 2:20 pm Up
Power steering pump could be on the way out.
Tolkienfan001
PostPosted: Fri Jan 25, 2013 2:21 pm Up
Trade Rating: +13
Would there be more warning signs before it went? Of will it be a case if fine today no steering tomorrow? I have had a look Ecp do them fairly cheap.
2005 1.4 16v Sport
20Drift
PostPosted: Fri Jan 25, 2013 2:38 pm Up
Could you possibly get a video or audio recording of the sound as it happens?
Tolkienfan001
PostPosted: Fri Jan 25, 2013 2:44 pm Up
Trade Rating: +13
Yea thought about this earlier. Will have a go tomorrow. How do I post a video?
2005 1.4 16v Sport
PostPosted: Fri Jan 25, 2013 4:58 pm Up
Pump going, mines doing it.
Tolkienfan001
PostPosted: Fri Jan 25, 2013 10:53 pm Up
Trade Rating: +13
So to change the pump what do I need to buy?
Pump - found one on Ecp
Fluid - holds 1litre but should I buy more
Belt - is it called the auxiliary belt?
What should I expect labour to cost?
2005 1.4 16v Sport
