Latest: airmastertapes
Overall: 17133
Online Now [321]:
Visitors: 320
Today: 40698
Total: 106752601
Forums › The Car › 206 Talk › Front wing - is the cc the same as any other model?
JNRS
PostPosted: Sat Jan 26, 2013 5:52 am Up
I need to buy a second hand front wing for my 03 cc and was wondering if a wing from any other model is the same..? I have been told for example that the gti wing is the same..?
PostPosted: Sat Jan 26, 2013 6:04 am Up
GTi, XSi...err...Si (the SW version) and later Sport range cars use Sports wings.
