Online Now [109]:
Visitors: 108
Today: 57356
Total: 117011318
Forums › The Car › 206 Problems › Changing Diesel Pump
apache1311
PostPosted: Mon Jan 28, 2013 5:52 pm Up
Hi All
I have a 2001 206 1.9d lx and just bought a replacement fuel injector pump as the old pump is causing me problems.
I tried searching for instructions how to bypass the immobiliser, as the current pump is already bypassed.
Its a lucas pump
Anybody know the procedure for doing the bypass
Cheers
N
PostPosted: Mon Jan 28, 2013 7:22 pm Up
Why would you want to bypass the immobiliser?
In any case, I wouldn't have thought it would be a change in the pump, but in the circuitry that controls the pump.
southwestchap
PostPosted: Tue Jan 29, 2013 4:07 am Up
need to look at the solenoid on the right side of the pump (near where the injector lines fit to it) it'll probably have an anti tamper cover on it.
if you could access it, just swap the solenoid for an off the shelf standard 1 wire one.
can you not compare the old pump to the new pump?
