Online Now [119]:
Visitors: 118
Today: 15756
Total: 106145453
Forums › The Car › 206 Problems › will a gti gearbox fit an xsi
rus18
PostPosted: Tue Jan 29, 2013 6:23 am Up
Hi does anyone know whether a 206 gti gearbox would fit a 206 xsi? Thanks
tinman
Lecktorious
PostPosted: Tue Jan 29, 2013 6:24 am Up
Trade Rating: +59
Yes, but not easily or cheaply.
'98 Nile Blue 306 GTi 6
rus18
PostPosted: Tue Jan 29, 2013 9:37 am Up
Okay thanks is it really that different?
tinman
PostPosted: Tue Jan 29, 2013 9:40 am Up
Need a conversion kit, expect a few grand to set you back
PostPosted: Tue Jan 29, 2013 12:13 pm Up
The BE4 gearbox is fitted to TU engines in the Picasso etc isn't it? So if you just want GTi ratios you'd need one of those to convert.
