Latest: KevinRC
Overall: 17137
Online Now [1251]:
Visitors: 1249
Members: 1
Today: 39451
Total: 111074165
Forums › The Car › 206 Problems › Clicking Ignition
Clicking Ignition
ReignSupreme
PostPosted: Wed Jan 30, 2013 1:19 pm Up
I'm sure I've had this problem before BUT, I can't remember how I sorted it. All my 206 is doing when you turn the key is clicking repeatedly and not even turning the engine. I've read that it could be the starter solenoid but maybe it just needs a bump start? It has sat on the drive for several months. I've recharged the battery and checked all the terminals and they're fine. Any guidance?
PostPosted: Wed Jan 30, 2013 1:23 pm Up
Checked the earth strap on the gearbox?
ReignSupreme
PostPosted: Wed Jan 30, 2013 1:25 pm Up
Yeah, that's fine.
PostPosted: Wed Jan 30, 2013 1:29 pm Up
Checked the connections on the starter motor? Given it a wack with a hammer?
P6RAF
PostPosted: Wed Jan 30, 2013 1:34 pm Up
Could put a meter over the battery when you crank the engine to ensure the battery is operating under load OK. Just because a battery has been charged doesn't rule out that it's not at fault.
Process of elimination.
2004 206 HDi GTi, Obsidian Black.
VW Polo 1.3 GL - 205 GTI 1.6 - 306 D-Turbo - First 205 GTI 1.9 track car - Second 205 GTI 1.9 Track car - 106 XLD - Impreza WRX - 406 V6 - 206 HDi GTi
Steve-o
PostPosted: Wed Jan 30, 2013 2:01 pm Up
Having just had a similar problem I'd go for checking your battery and your main leads as others have said and (though I'm sure you've done this) check you haven't blown a fuse. Check fuse 7 under the bonnet first. My problem lay at the starter motor.
