Latest: Daz682237
Overall: 17136
Online Now [151]:
Visitors: 150
Today: 17922
Total: 110877406
Forums › The Car › 206 Problems › plexed/non-plexed front foglamps
PostPosted: Fri Feb 01, 2013 1:28 pm Up
weird one here the front foglights on my gti 180 worked fine fitted the gt bumper and the fogs supplied and the fogs dont work checked the car was ok by plugging in the old fogs and they work fine so must be the gt foglights Confused replaced the bulbs and visually checked the wiring and still not working going to test them with a circuit tester tommorow but i really cant see why they look ok yet neither are working Crying or Very sad
do you have to reverse the plug or are they different in anyway??
cheers
PostPosted: Fri Feb 01, 2013 1:35 pm Up
Plugs are identical as well as the wiring. Must be a bad contact on the fog somewhere or a broken wire inside them.
RoweY
PostPosted: Fri Feb 01, 2013 2:50 pm Up
I also have this problem all connections are fine, worked perfect then just one day they stopped working. I have changed the bulbs and checked all wiring etc... and still no joy! Sad
PostPosted: Fri Feb 01, 2013 3:56 pm Up
damn just my bloody luck just thought it was weird they were both like it Confused looks like im doing a bit of rewiring then Rolling Eyes
cheers guys
PostPosted: Fri Feb 01, 2013 4:31 pm Up
test the GT fogs by turning them on with an outside voltage,then see if they work or not,if they work,then the gray plug is not the right one,i mean the one u have on your 180
