Online Now [1154]:
Visitors: 1153
Today: 294994
Total: 149044978
Forums › The Car › 206 Problems › Diesel Knock
Diesel Knock
apache1311
PostPosted: Sun Feb 03, 2013 9:43 am Up
Hi All
I changed my diesel pump on my 206 1.9d LX 2001 last week.
Since changing the pump i am getting a rather loud diesel knock now.
When setting the timing I locked the engine up, Flywheel, Cam and pump.
After all was tight i turned engine over with a spanner about 8 times and was able to lock all the points back up again.
What could it be.
Cheers
N
apache1311
PostPosted: Fri Feb 08, 2013 9:28 am Up
The strange thing about this problem is that it is not all the time
When u start it, it sounds ok and then a we rev and it ok then the knock would happen.
Could it be a faulty injector
apache1311
PostPosted: Sat Feb 09, 2013 6:27 am Up
Cheers
I did get the injectors tested and they said they were fine.
Today i disconnect the electrical connecting plug to injector 1
It made no difference to the engine. Yesterday for about 5 minutes i had no knocking at all while driving then it started again.
Has same the morning for about 2 mins and no knocking.
I also disconnected the plug going to the regulator (at the side at bottom of pump - lucas pump) on the diesel pump, not the stop solenoid, it did not make one bit of difference if connected or not.
I put a multi-meter on the pins and i am seeing 12v on one and .87 on the other. i do not know if this correct reading.
N
