Latest: lio94
Overall: 17181
Online Now [213]:
Visitors: 212
Today: 59123
Total: 141926207
Forums › The Car › Solved 206 Problems › Track rod end? Been to garage update 05-02-13
Tolkienfan001
PostPosted: Mon Feb 04, 2013 12:12 pm Up
Trade Rating: +13
Guys.
The car is a 2005 1.4 16v.
I believe my track rod end is failing. When I grap the passanger front wheel at 3 and 9 and rock the wheel there is some play and a slight knocking sound.
When driving the car the steering feels slightly wobbly / jumpy at times. It is pulling slightly to the left and twitches at changes in the road.
I am looking to buy this:
www.eurocarparts.com/e...0e0&000349
Would you agree with my diagnosis and is this the best / correct part?
2005 1.4 16v Sport
Check out my 206 here!
206gti_chris
PostPosted: Mon Feb 04, 2013 12:32 pm Up
i had similar problems and had it checked by a mechanic and told me to get the drop links changed, so i got them done problem solved
Tolkienfan001
PostPosted: Mon Feb 04, 2013 12:40 pm Up
Trade Rating: +13
I would have thought with a drop link issue I would be hearing a noise while driving and especially going over bumps etc. my issue has no sound with it, except when I shake the wheel?
2005 1.4 16v Sport
Austin
PostPosted: Mon Feb 04, 2013 12:52 pm Up
could be a wheel bearing...
Tolkienfan001
PostPosted: Mon Feb 04, 2013 12:53 pm Up
Trade Rating: +13
Again wouldn't a bearing make noise while driving?
2005 1.4 16v Sport
Austin
PostPosted: Mon Feb 04, 2013 1:08 pm Up
mine only made a noise when turning to the right, fine in straight line.
usher
drop link mine needed tightening by 1/8th a turn
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Tolkienfan001
PostPosted: Mon Feb 04, 2013 1:10 pm Up
Trade Rating: +13
Mine makes no noise when turning?
2005 1.4 16v Sport
richpowell91
PostPosted: Mon Feb 04, 2013 1:36 pm Up
Get someone too look at the track rod end and also the lower arm balljoint, as you shake the wheel, it should be fairly obvious to see where the play is.
Tolkienfan001
PostPosted: Mon Feb 04, 2013 1:40 pm Up
Trade Rating: +13
Ok will do that tomorrow. Thanks. Just don't want to replace a part that Is not worn.
2005 1.4 16v Sport
PostPosted: Mon Feb 04, 2013 1:43 pm Up
Have you confirmed inner or outer?
Is there play in the bottom arm? Is the wheel bearing failing?
More checks are required
Tolkienfan001
PostPosted: Mon Feb 04, 2013 1:46 pm Up
Trade Rating: +13
I think my best bet is to take it to the garage and ask them to check it all out. I will then fix what they find.
2005 1.4 16v Sport
PostPosted: Mon Feb 04, 2013 1:55 pm Up
Its your choice, but if you are 100 percent checking at 9 to 3 and can 'feel' play it will be a track rod joint.
To confirm which one you will need a second person to see where it is, if not place your hand over the outer joint to feel for play then the inner in the gaitor.
If you still cant feel it pull down on the track rod as close to the inner gaitor as possible and move the wheel about at the points (3-9) and see if the play has disapeared. If it has, inner, if not outer
Simples Smile
Tolkienfan001
PostPosted: Mon Feb 04, 2013 1:58 pm Up
Trade Rating: +13
Simples Smile
That sounds straight forward. I will have a look after work tomorrow. If I am still not sure i will get the garage to double check.
2005 1.4 16v Sport
PostPosted: Mon Feb 04, 2013 2:00 pm Up
Fair play dude, i would personally rape a peugeot main stealers for a FREE VHC but decline all work afterwards
Free health check on your car with no price, win win?
