Online Now [732]:
Visitors: 731
Today: 107381
Total: 145790718
Forums › The Car › 206 Problems › phase 2 rears fitted sweet, but.......
tom2581
PostPosted: Wed Mar 13, 2013 12:25 pm Up
i fitted phase 2 rear lights today when it wasnt snowing, tbh they look a lot better than the phase 1 apart from the enormous gap between boot lid and lights Confused is this normal or anyway to rectify ?
Cr4zYb0y
PostPosted: Wed Mar 13, 2013 12:37 pm Up
Yeah its normal..
1.6 16v XSi Member #21
KILL COUNT: Twisted Evil
Pigeon IIIII
Dove I
Rat/Mouse I
Rabbit I
Hedgehog I
PostPosted: Wed Mar 13, 2013 1:03 pm Up
I take it you located the front peg in to the clear plastic bung in the body correctly?
tom2581
PostPosted: Wed Mar 13, 2013 1:30 pm Up
yup i even triple checked everything, i just under impression its a poor fit, i'll have a gander at some the 206's on car park friday an compare lol
PostPosted: Wed Mar 13, 2013 1:37 pm Up
Did they come with the foam seal to stop water getting into the boot?
tom2581
PostPosted: Wed Mar 13, 2013 1:57 pm Up
yup the foam seal is there on back of the lights, i even slackened them off thinking i had over tightened them but made no difference to how the boot lid sits ? Mad
A18NHH
PostPosted: Wed Mar 13, 2013 2:44 pm Up
they're not from a 206CC are they?
Sure someone will say this shouldn't matter though?
Wahoo!
PostPosted: Wed Mar 13, 2013 3:33 pm Up
It WONT
Only the black plastic splash shield is different between CC / hatch & there only clipped on & swappable anyway Wink
tom2581
PostPosted: Wed Mar 13, 2013 3:39 pm Up
no they were off a member on here a smashed up 3 door seen the car in person so deffo not a cc lol
gpvecchi
PostPosted: Wed Mar 13, 2013 4:41 pm Up
Well, simple solution... Loose the nut that keeps light in place... If it's too tight it leaves gap, if it's too loose, light will move.
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
Lecktorious
PostPosted: Wed Mar 13, 2013 5:52 pm Up
Trade Rating: +59
Try adjusting the tailgate latch. You might be able to get the tailgate sitting more flush, reducing the panel gap.
'98 Nile Blue 306 GTi 6
tom2581
PostPosted: Thu Mar 14, 2013 7:35 am Up
yeah i tried that they kept movin so tightened back up, gonna see if i can adjust the latch a little, i just swapped out the boot strip for a phase 2 only to find laquer damage not havin much luck with this boot lid at all might see if i can find another anyone got one cheap in diablo red lol
PostPosted: Thu Mar 14, 2013 12:15 pm Up
Bend the tailgate,
OR add another set of seals on the back to take the slack,
OR fit Ph1 set as the geniuses at Peugeot originaly intended.
