Posted: Thu Oct 25, 2012 3:46 pm |
My car made a terrible judder this morning when I pulled away in 1st gear.
It seems to disappear once the engine has warmed up.
Is this the clutch on the way out? ![Sad Sad](images/smiles/icon_sad.gif)
| | ![](images/spacer.gif) |
Posted: Thu Oct 25, 2012 6:00 pm |
possible but its not likely to just go on you, see what its like in the morning
| Tripple P\'s......PURE PUG POWER | |
Posted: Fri Oct 26, 2012 8:53 am |
Well it was ok this morning.
I am sure that the clutch is on its way out soon though as the car has done nearly 60K and it has never been replaced.
I don't know how long a clutch last but its got to be due soon surely!
Posted: Fri Oct 26, 2012 9:37 am |
I wouldn't worry about it. The clutch on our 207CC is always like this from cold. The rest of the time it's perfect and it's only done 29k miles.
Posted: Fri Oct 26, 2012 9:42 am |
Edward wrote: |
and it's only done 29k miles. |
29k its done 60K!
Posted: Fri Oct 26, 2012 9:44 am |
60K is nothing to clutch, still got loads of meat left when i change the clutch around 75K
Posted: Fri Oct 26, 2012 10:26 am |
A10PSW wrote: |
I don't know how long a clutch last but its got to be due soon surely! |
My brothers car has done 129k and has never had the clutch replaced. Depends how you drive it.
Posted: Fri Oct 26, 2012 10:31 am |
129K Wow, I will see how much longer I can get away with it on mine!
Posted: Fri Oct 26, 2012 10:37 am |
Trade Rating: +13
My Astra (just been scrapped) was 148k with original clutch and had only just had the original battery replaced. Had not been serviced for 6 years! Sometimes cars have few issues in these areas.
Posted: Wed Oct 31, 2012 5:33 pm |
I had a similar thing a little while back, turned out to be the clutch slipping which meant an expensive trip to the garage for a new clutch. Does yours slip in any other gear, or just the judder in first?
Posted: Thu Nov 01, 2012 2:20 am |
kippo2012 wrote: |
I had a similar thing a little while back, turned out to be the clutch slipping which meant an expensive trip to the garage for a new clutch. Does yours slip in any other gear, or just the judder in first? |
It juddered when I pulled away.
But if I am careful with the clutch it does'not do it!
Posted: Thu Nov 01, 2012 12:18 pm |
That's what mine started out like, then over a few weeks it got worse to the point where it'd slip out of gear as I was driving along.. Which was quite annoying
Posted: Thu Nov 01, 2012 1:24 pm |
Also how both my gearboxes started. ![Laughing Laughing](images/smiles/icon_lol.gif)
| Project Low and Slow.. Going Euro for 2013. Keep your eyes peeled, big plans ahead..
See my project here. | |
Posted: Thu Feb 07, 2013 2:55 pm |
A clutch can be anything between 40k and 200k depending on your driving style (aggressive or sympathetic) and whether you do mainly motorway or short town driving in traffic.
Posted: Thu Feb 07, 2013 3:06 pm |
It all depends how high the clutch bite on the pedal is, if its quite near the top, I would think about changing the clutch. If its not, I'd keep an eye on the judder to make sure it doesnt get worse.
