Latest: tbafonso
Overall: 17130
Online Now [230]:
Visitors: 229
Today: 40623
Total: 104622373
Forums › The Car › 206 Problems › 206 gti 180 cambelt
206 gti 180 cambelt
samfrygti180
PostPosted: Sun Feb 10, 2013 1:02 pm Up
Fitted new cambelt and water pump on saturday but since then its right down on power and cuts out if you floor it then back off the throttle
any ideas?
Big_Rich180
PostPosted: Sun Feb 10, 2013 1:03 pm Up
Badly fitted cam belt, id you use all the correct locking tools?
Barking
PostPosted: Sun Feb 10, 2013 1:07 pm Up
Incorrectly timing?
Slack belt?
I got a dig bick.
You that read wrong.
You read that wrong too.
samfrygti180
PostPosted: Sun Feb 10, 2013 1:09 pm Up
all correct tools used found it very hard to time it up couldnt find it autodata books
my engine code is rfk
but for that in the books it a 4 bolt bottom pulley but mines a 1 bolt floater
the only way we could get it to time up was to a 2.2 406 coupe
Big_Rich180
PostPosted: Sun Feb 10, 2013 1:11 pm Up
If you've lost power after doing the belt the timing will be out.
I cant elaborate on how to get the timing correct other than take it to Peugeot or a french car specialist.
richpowell91
PostPosted: Sun Feb 10, 2013 1:33 pm Up
Just looked at autodata, what position where the camshafts locked off at (position of locking tools) See the two photos attached to see the difference.
406 2.2
180
samfrygti180
PostPosted: Sun Feb 10, 2013 1:39 pm Up
it was very strange would lock off to both but soon as you tried turning it over after doing it at the 180 it would lock up on number 1 on inlet but then done it to the 2.2 and it worked i had a couple of experienced mechanics look at it and they were baffled at it
is there anyone in the south that has vast experience on doing these that could just take a look?
Big_Rich180
PostPosted: Sun Feb 10, 2013 1:42 pm Up
The south where mate, its quite a big area lol.
samfrygti180
PostPosted: Sun Feb 10, 2013 1:49 pm Up
Bournemouth lol.
HDI90
PostPosted: Sun Feb 10, 2013 3:00 pm Up
Its timed up wrong, i recall what people call a floating crank so if you dont know what you are doing then you in the tom tit!
GTI 180
broadblaster
PostPosted: Sun Feb 10, 2013 3:16 pm Up
problem is its not so easy to "just take a look" really you need to strip it all back down and start again so as you know this is not a 5min job on the 180's.
on a back road playing
PostPosted: Mon Feb 11, 2013 10:03 am Up
any ideas?
Yes, your out of your depth & haven't got a clue what your doing Wink
Also the phrase " All the gear & no idea " springs to mind.
