Latest: lio94
Overall: 17181
Online Now [390]:
Visitors: 389
Today: 27820
Total: 141338569
Forums › The Car › 206 Problems › vibration
vibration
dan1995206
PostPosted: Sat Feb 09, 2013 11:20 am Up
I have a problem when i am on the highway my car starts to vibrate around 60-70mph. I had the wheels balanced the other day and the mechanic said that they were really bad and didn't know how i'd kept it on the road. it still does it now although it drives much better, anyone know what this could be caused by?
TheGTIlad
PostPosted: Sat Feb 09, 2013 6:13 pm Up
It could be possible that one of the new wheel weights have fallen off again, or it could be the fact that one of your alloys is bent.
PostPosted: Sun Feb 10, 2013 5:48 am Up
Driveshafts knackered.
PostPosted: Sun Feb 10, 2013 6:30 am Up
Is the vibration coming through the steering or through the car?
Could be an number of things from suspension or steering parts worn, twisted tyre, driveshafts, warped brake discs, or even different tyres on the same axle.
PostPosted: Sun Feb 10, 2013 7:05 am Up
+1 macca1411
Did you have all 4 ballanced?
Is the vibration felt through the steering or through your a**e - i.e. whole car is vibrating.
It may be worth moving front wheels to rear and seeing if the vibration moves.
If tyres are badly out of balance for a long time you can get weird tyre tread wear pattern enough for the vibration to continue and only new tyres fix it. It is unusual but does happen.
Could be drive shaft.
dan1995206
PostPosted: Sun Feb 10, 2013 7:55 am Up
Its mainly through the steering but the car vibrates some times as well, i'm going to take it to my mechanic tomorrow as its really starting to frustrate me.
Peugeot 206 1.4 Diablo Red
PostPosted: Sun Feb 10, 2013 9:09 am Up
dan1995206
PostPosted: Sun Feb 10, 2013 2:28 pm Up
Went for a drive this afternoon felt like the front was running okay but felt like the rear shaking a bit !
PostPosted: Sun Feb 10, 2013 3:54 pm Up
OK.
Let us know when you sort it.
dan1995206
PostPosted: Sun Feb 10, 2013 3:59 pm Up
Will do.
