Online Now [479]:
Visitors: 478
Today: 103045
Total: 106297175
Forums › The Car › 206 Problems › Another Central Locking Topic
rickdo
PostPosted: Mon Feb 11, 2013 2:16 pm Up
Hi All,
I've just purchased a Peugeot 206 1999 1.4 second hand.
It's a lovely car and im liking everything about it. Stupidly before buying it i forgot to check the central locking on the car and am now able to lock all the doors manually except for the boot.
I have tried resynching my key to the car with no success and when i press the unlock button on the key there are a series of clicking sounds (4 in total) from underneath the steering wheel but no action to any of the locks.
So confirming it is receiving a signal and unable to find a bloody relevant owners manual im at a loss.
Can anyone shed any light on manually locking the boot or finding the issue with my locking?
Thanks!
PostPosted: Mon Feb 11, 2013 2:29 pm Up
You can lock it ffrom the inside, just take the plastic cover off from inside and slide the metal bar across to lock it. The motor is probably burned out.
rickdo
PostPosted: Mon Feb 11, 2013 4:11 pm Up
Thanks, was doing that while waiting for a reply Razz
None of the doors locks work centrally, would they have all blown?
PostPosted: Mon Feb 11, 2013 4:23 pm Up
Check the central locking fuse? Do they lock altogether with they key in the door, or do they 'bounce' when you use the remote central locking
rickdo
PostPosted: Mon Feb 11, 2013 4:34 pm Up
I don't have the manual for my car so i didn't know which fuse was for my model.
I checked with another 206 manual (the CC one) and it wasn't the same as mine so i didnt change anything. Looking at the fuses tho they all look good, no snapped wires or melted fuses
rickdo
PostPosted: Wed Feb 20, 2013 11:09 am Up
They don't bounce though, they do nothing. only thing that happens is there is a clicking noise from underneath the steering wheel. They don't lock altogether with the key in the door, it only locks the door the key is in
paulsc
PostPosted: Mon Feb 25, 2013 12:49 pm Up
Apologies Rickdo for jumping in on your thread but I now also have the same symptons on my son's 2000 peugeot 206.
All started when I swapped out some of the 20A fuses on the internal fusebox to try and get the cigarette lighter working once again. Didn't have my multimeter with me so reverted to the old fashioned way of swapping out fuses. Ignition was always switched off at the time of swapping fuses.
Cigarette lighter now works but central locking buggered.
Same as above, lots of clicking underneath steering wheel but no action at all from any door lock motors, bouncing or otherwise. However, indicator lights do flash and alarm can be set as if everything was working ok but doors just do not lock electronically.
Have checked all fuses visually and tried swapping fuse 16 (30A) with a brand new fuse with no change.
Struggled to find relevant fuse but found this on the forum:
type a search for "FAQ: Pre-plexed fuse list."
which sort of helps to try and identify relevant fuses.
Engine Fuse Box
Fuse - Rating - Circuit Protected
MF1......70A......Built in Systems Interface supply
MF2......40A......Fan
MF3......-----......Additional heating
MF4......-----......Spare
MF8......70A.......Supply passenger comp. fuse box
MF9......50A.......Built in Systems Interface supply
MF10....40A.......Main and dipped beam
MF11....60A.......Supply passenger comp. fuse box (models with rear power windows)
MF12....50A.......Ignition switch power supply
MF13....40A.......Ignition switch power supply
MF19....30A.......ABS
MF17....30A.......ABS
F5......20/30A....Horn, sidelights, front foglight
F6......10/20A....Heated seats, heating, ventilation, running lights
F7......5/20A......Fan
F14....5/30A......Running lights, headlight wash, diagnostics socket
F18....----- .......Spare
F19....----- .......Spare
F20....----- .......Spare
F21....5A..........Coolant thermostat
F22....----- .......Spare
F23....5A..........ABS
F24....5A..........Engine Management, pre-heat unit, ventilation
F25....10A.........Fuel Pump
F26....10/30A....Engine management, fuel pump, oxygen sensor, EGR
F27....-----....... Engine management
F28....5A..........Throttle housing heater
F29....30A........Air pump
F30....10A........RH foglight, foglight warning light
F31....10A........LH foglight
F32....10A........Reverse light, speed sensor, diesel pump, auto gearbox, additional heating
F33....10A........Automatic gearbox
F34....5/15A.....oxygen sensor
Passenger Fuse Box (28 fuse)
F1......SH..........Pre tensioner unit, front and side airbags, BSI supply
F2......5A..........Instrument cluster
F3......----- ......Spare
F4......5A..........Built in systems interface (BSI)
F5......----- ......Spare
F6......5A..........Engine management control unit, immobiliser
F7......5A..........Spare
F8......10A........Coolant temp unit, instrument panel, hazard warning, clock, multi/funct display, courtesy light
F9......5A..........Built in systems interface (BSI)
F10....----- .......Spare
F11....10A.........LH stop light, high level stop light
F12....10A.........RH stop light
F13....----- .......Spare
F14....30A.........Rear electric windows
F15....20A......... Luggage compartment illumination, tow-bar supply
F16....----- .......Spare
F17....----- .......Spare
F18....10A.........Number plate light, lighter illumination, clock, multi/funct display, interior illum.
F19....5A...........Rear foglight
F21....----- .......Spare
F22....10A.........Glovebox light, map light, courtesy light, clock, instrument panel, sat-nav, rear electric windows, .........................rain sensor
F23....20A.........Cigar lighter
F24....15A.........Radio
F25....20A.........Windscreen wiper and rear wiper
F26....----- .......Spare
F27....5A...........Built in system interface (BSI)
F28....----- .......Spare
Passenger Fuse Box (12 fuse)
F29....10A.........LH main beam
F30....10A.........RH main beam, main beam warning light
F31....10A.........LH dipped beam
F32....10A.........RH dipped beam, dipped beam warning light
F33....5A...........Headlight wash
F34....10A.........LH side/tail light
F35....10A.........RH side/tail light
F36....----- .......Spare
F37....----- .......Coolant temperature unit
F38....5A...........Fan, pressostat
F39....----- .......Spare
F40....20/40A....Heating, ventelation
The picture towards the bottom of the replies shows the identical fuse layout to my son's Peugeot, but I question whether the fuse table correlates (1) F11 is quoted to be 2 from right on the bottom row. Isn't it second from left on the top row?
Also, my son's car has 3 off 15A fuses and 2 off 30A fuses which doesn't correlate with the table.
The bottom row looks more like "Passenger Fuse Box (12 fuse)" with F40 being the only 40A fuse in this box.
In my wife's Peugeot 206 2002 Haynes manual the only fuses linked to central locking are MF04 (70A in engine), MF07 (30A in engine) and F16 (30A internal). Have checked all engine fuses and all are ok - both these engine fuses are also used by numerous other items such as electric windows, wipers, washer, etc so this double checks they are ok. F16 however is more difficult for me to identify in the older model Peugeot but assuming it is indeed a 30A fuse then there are only two to try if they are located as per the diagram above and both these were swapped out with a new fuse to no avail.
Have also tried re-programming the key fob and again this did not work.
My questions are:
1. Which fuse on the picture in the link above are related to the central locking?
2. With the symptons defined above and as per rickdo's original post, could be the cause of the central locking problem?
paulsc
PostPosted: Mon Feb 25, 2013 2:17 pm Up
Just been trawling through this forum and wandered if a BSI reboot would solve the problem.
Can you reboot the BSI on a Peugeot 206 (year 2000)?
If so, can a novice like myself do the reboot?
kulitone
PostPosted: Sat May 18, 2013 6:28 am Up
I cannot find the fusebox on my 2002 hdi 206 there's about 8 little fuses below steering wheel and some under bonnet please could some one explain where it is
steven scales
PostPosted: Sat May 18, 2013 6:47 am Up
There is no BSI reset on a non-mux (<Oct.2001) 206.
antoniomal
PostPosted: Sun Jan 26, 2014 10:50 am Up
I have the same problem.. Anyone worked out what it may be??
