Online Now [557]:
Visitors: 556
Today: 38302
Total: 105080626
Forums › The Car › 206 Problems › Hard to remove rear pads -> piece merged with caliper
kernel
PostPosted: Tue Feb 12, 2013 7:30 am Up
hi there
I was trying to remove the rear pads, following this how-to www.206info.co.uk/Foru...=3756.html
all was fine but just in the 2nd step, I've been unable to detach this L shaped bar
oxide seems to have done good job Rolling Eyes . I've been for half an hour hammering it. Evil or Very Mad
this is how it should be removed, pushing this way:
any ideas how could I detach it? WD40 for one night? Confused
thanks
PostPosted: Tue Feb 12, 2013 7:40 am Up
Get brutal on the L bar, a decent brand of pads should come with a pair of shiny new bars & clips.
PostPosted: Tue Feb 12, 2013 9:14 am Up
Wire brush, plenty of heat and the biggest hammer you can get at it will soon shift it.
DanT
PostPosted: Tue Feb 12, 2013 12:33 pm Up
They will budge in the end. Just persevere! If you don't muller it completely you can clean it up with a file after and re-use it.
PostPosted: Tue Feb 12, 2013 1:53 pm Up
Take the pin out and whack it! Shouldn't take too long. You won't break anything.
PostPosted: Tue Feb 12, 2013 2:08 pm Up
I have had a crap day. Where do you live? I will come round and shift the b****y thing!
PostPosted: Tue Feb 12, 2013 4:18 pm Up
When you get it to move a bit get some plus gas or similar on it. Then hammer it back to where it was and then back out again will make it a lot easier if it's that bad.
devotedsniper
PostPosted: Wed Feb 13, 2013 8:01 am Up
I've always found a rubber mallet to be highly effective when it comes to getting pretty much any brake part off...
Now a 2010 Renault Megane Coupe owner
PostPosted: Wed Feb 13, 2013 1:47 pm Up
Not sure how you hit something that small with a rubber mallet!
mtempsch
PostPosted: Wed Feb 13, 2013 2:11 pm Up
You put a drift punch (or other suitably shaped piece of metal) in between...
Silvermetallic 2004 206 RC
PostPosted: Wed Feb 13, 2013 2:26 pm Up
New fitting kit then just t**t the old bars out Whistle...
