Posted: Wed Feb 20, 2013 8:35 am |
After doing a little digging I believe that my heater resistor has failed as I only have the use of setting 4 on the fan.
Where's the best place to buy another resistor and is it a fairly easy fix?
This is the first job in a long string on jobs that need doing on a car I've just got!
Posted: Wed Feb 20, 2013 9:14 am |
Yes.
Posted: Wed Feb 20, 2013 9:45 am |
Get another fan. The resistor isn't just some little farty thing you see on circuit boards.
Plus finding one with the exact resistance values with the correct steps you give you the different speeds would be difficult at best.
Posted: Wed Feb 20, 2013 10:00 am |
Posted: Wed Feb 20, 2013 10:12 am |
| AX-Rated wrote: |
The resistor pack is available as a spare part for PSA stuff without climate control fitted.
Last time I checked the price new from Peugeot / Citroen they where pretty cheap.
Posted: Wed Feb 20, 2013 3:20 pm |
The resistor has melted, along with probably the earth on your connector
End thread.
| Team Impossible Possible
Posted: Thu Feb 21, 2013 4:40 am |
Not exactly end thread, is it easy to access and replace?
Posted: Thu Feb 21, 2013 7:42 am |
| MrBSI wrote: |
| AX-Rated wrote: |
Last time I checked the price new from Peugeot / Citroen they where pretty cheap. |
Well tickle my tits til Tuesday. Learn something every day.
Posted: Thu Feb 21, 2013 4:54 pm |
| Matt106 wrote: |
| Not exactly end thread, is it easy to access and replace? |
Probably, stab in the dark with a pork sword
6.5 out of 10 easy
