Latest: tbafonso
Overall: 17130
Online Now [189]:
Visitors: 189
Today: 18262
Total: 104373556
Forums › The Car › 206 Problems › Top Mounts
Top Mounts
Jasoon
PostPosted: Fri Feb 22, 2013 9:03 am Up
does anyone know of the top of there head what torque the top mount bolts should be?
As ive just found two of them where loose.....
PostPosted: Fri Feb 22, 2013 9:46 am Up
15lb ft
Jasoon
PostPosted: Fri Feb 22, 2013 11:35 am Up
thanks for that Edward
PostPosted: Fri Feb 22, 2013 2:03 pm Up
Jasoon: buy a Haynes manual. Not perfect but it will give quite good description of repair work and list torque settings.
Jasoon
PostPosted: Fri Feb 22, 2013 2:40 pm Up
Will do but found them loose while doing another job
