Posted: Sat Feb 23, 2013 9:58 am |
I've recently bought a 04 plate 206 hdi gti.The rear wiper will only activate when i select reverse gear.Any suggettions as to what the problem might be will be greatly appreciated.
Posted: Sat Feb 23, 2013 11:35 am |
Trade Rating: +13
Comms unit. Mine had the same issue. Bought a new unit from ECP. Problem solved.
Posted: Sat Feb 23, 2013 1:01 pm |
do u mean that when your front wipers working,and you select reverse it works?? if that is the case,then it's normal,but if it's not working when you turn the switch,then as said above,you need a new com2000
Posted: Sat Feb 23, 2013 1:49 pm |
Trade Rating: +13
Yea mine did exactly that. Would not work on the switch, but when I had the front wipers on and reversed the wiper worked.
Posted: Sat Feb 23, 2013 2:44 pm |
Thanks for the assistance.Can anyone please give me a link for the unit that is required.
Posted: Sat Feb 23, 2013 2:51 pm |
Trade Rating: +13
