Online Now [135]:
Visitors: 134
Today: 53381
Total: 138732327
Forums › The Car › 206 Talk › Any1 no if theres a fuse for outside temperature reading???
mikeygti180
PostPosted: Sun Mar 03, 2013 8:54 am Up
As above ,, thanx in advance
gti180
mtempsch
PostPosted: Sun Mar 03, 2013 1:57 pm Up
As far as I'm aware there's no fuse specific for the temperature, IIRC it's just the passenger mirror housing sensor connected to the display board...
Silvermetallic 2004 206 RC
mikeygti180
PostPosted: Sun Mar 03, 2013 3:09 pm Up
Is it possible to change the sensor in the wing mirror
gti180
PostPosted: Sun Mar 03, 2013 4:59 pm Up
Yes
mikeygti180
PostPosted: Sun Mar 03, 2013 5:19 pm Up
Ok its kuz ive got a wing mirror with a sensor in but it not a gti one so il get striping it apart cheers
gti180
mikeygti180
PostPosted: Mon Mar 04, 2013 10:05 am Up
No good i took apart the second hand wing mirror n the sensor plugs were completely different Sad
gti180
PostPosted: Mon Mar 04, 2013 11:58 am Up
The outside temp sensor hasn't got a plug on the 206, the official repair involves a soldering iron & heat shrink.
mikeygti180
PostPosted: Mon Mar 04, 2013 1:13 pm Up
Seems like a lot of hassle for a small part lol
gti180
mtempsch
PostPosted: Mon Mar 04, 2013 1:21 pm Up
Given that it probably uses a temperature variable resistor, it's likely a good thing to keep any possibly corroding (and thus increasing resistance) connectors to a minimum (especially ones located outside the passenger compartment/boot)
mikeygti180
PostPosted: Mon Mar 04, 2013 6:19 pm Up
I might give the connectors behind the wing mirror a clean up see if it makes any difference
gti180
