Online Now [637]:
Visitors: 636
Today: 177470
Total: 145287701
Forums › The Car › 206 Talk › (Stupid question I guess)disconnect battery
Forum Index › 206 Talk
arrjmai
PostPosted: Fri Mar 01, 2013 12:07 pm Up
Hey Guys Thanks for having this website since I am a lonely 206 user in my country this community helps me a lot.
My stupid question is. Since I did only have those car that I did not have to worry about BSI thing. I could just disconnect the - of battery when I left my home for travel and reconnect when I am back home and it's fine.
I will have to travel aboard for two weeks. I am traveling a lot and each time I asked my neighbor to start my car every three days two times a week.
Last time my neighbor also left home so I left my car for three weeks when I come back all battery power has drained off and I have to call service maintenance from Peugeot which they charged me like 30 GBP for just resetting BSI.
May I ask you question. I have been looking at the thread about disconnect reconnect battery reset BSI which is super useful.
If I disconnect battery follow by that procedure from the thread. Can I left my car with battery disconnect for two weeks and is it going to be fine when I am back and reconnect it again. I used to disconnect the - one only with my old car and when I am back even left the car for a month the re connection is always work.
Thank you so much. I am really appreciated you guys and 206 info
206info.co.uk
mtempsch
PostPosted: Fri Mar 01, 2013 12:47 pm Up
2 weeks should be no problem, unless there's already an internal fault in the battery causing rapid self discharge - and then it would be time for a new battery soon anyway (this fall my battery was failing - worked fine if I drove the car daily, but if I left it over the weekend it was flat on Monday morning, not even a hint of cranking... After the second time starting by hooking up a spare battery with jumper cables I replaced it.)
Silvermetallic 2004 206 RC
arrjmai
PostPosted: Fri Mar 01, 2013 1:51 pm Up
Hi Thank you for your prompted reply. I have just changed my battery from when my last time I left the car for one month and when I was back from travel battery was not in a good condition as it was about 2 years already so I decided to change to a new battery and this one was only six months old.
Thank you so I will just disconnect the battery to safe from the battery drain for two weeks. Thanks a lot
Ash
PostPosted: Sat Mar 02, 2013 2:31 am Up
You should invest into a trickle charger if you're away for long periods of time.
