The drivers seat adjuster on my 3 door wouldn't lock. I had to pull it back and forth before I could lock it and the adjuster on the right handside is loose. Have read about quite a few issues on this model, is this something easy to fix or an expensive garage job? Has anyone else had this problem?
iainlovatt
Posted: Sun Mar 03, 2013 11:19 am
Play with the heigh adjuster see if that helps.
What type of seats do u have?
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
