Posted: Sat Mar 02, 2013 2:25 pm |
Hello guys,
As title says,I wanna ask if I can relocate my car (1.4 8V) CAT,as you know it's located in front of the engine,so i'm thinking of changing it with a new one,but I want to know if change it's location would affect the car,and would there be EML light on because of the O2 sensor or not??
I'm thinking of fixing the new one under the engine.
Posted: Sat Mar 02, 2013 2:26 pm |
As long as you extended the downstream sensor (lower one) to after the CAT, no problems will occur
| Team Impossible Possible
Posted: Sat Mar 02, 2013 2:27 pm |
Why?
Its a lot of hassle for no gain.
Posted: Sat Mar 02, 2013 2:43 pm |
| Addaz wrote: |
| As long as you extended the downstream sensor (lower one) to after the CAT, no problems will occur |
The 1.4 8V have only one O2 sensor,and upper one,but there is a plug for a lower one ready for use.
Posted: Sat Mar 02, 2013 2:47 pm |
| Timon2210 wrote: |
| Addaz wrote: |
The 1.4 8V have only one O2 sensor,and upper one,but there is a plug for a lower one ready for use. |
Mines got 2 O2 sensors
Posted: Sat Mar 02, 2013 2:48 pm |
| MrBSI wrote: |
Why?
Its a lot of hassle for no gain. |
I don't wanna gain anything from this as a power or other stuff like may other think of,but the reason of this question is that,my car done 100,000 Kilo meter on the clock,and I have recently start to smell like a rotten egg ,so I can't find a brand new one to fit ,so thinking of fitting a universal CAT,and locate it under the engine like other models
Posted: Sat Mar 02, 2013 2:51 pm |
The cat should last a lot longer then that, that works out to just under 62.2k miles
Posted: Sat Mar 02, 2013 3:04 pm |
| MrBSI wrote: |
The cat should last a lot longer then that, that works out to just under 62.2k miles  |
I think the reason it might be faulty,that the engine sound is rough running,like a tractor,and air flow is not as good as it should be,and how come you have 2 sensors,and I have only one ;),did you fitted it yourself :D?
Posted: Sat Mar 02, 2013 3:11 pm |
If its placed under the engine, wont it be close to the floor?
Posted: Sat Mar 02, 2013 3:17 pm |
| Timon2210 wrote: |
| MrBSI wrote: |
I think the reason it might be faulty,that the engine sound is rough running,like a tractor,and air flow is not as good as it should be,and how come you have 2 sensors,and I have only one ;),did you fitted it yourself :D? |
It left the factory like that, downpipe cat with pre & post cat lambda sensors.
Posted: Sat Mar 02, 2013 3:22 pm |
| Steve206 wrote: |
| If its placed under the engine, wont it be close to the floor? |
not exactly under the engine,just behind it,close to the gearbox links
Posted: Sat Mar 02, 2013 3:24 pm |
| MrBSI wrote: |
| Timon2210 wrote: |
| MrBSI wrote: |
It left the factory like that, downpipe cat with pre & post cat lambda sensors. |
Would love to see a pic of that please,can you do it?
Posted: Sat Mar 02, 2013 3:27 pm |
| Timon2210 wrote: |
| MrBSI wrote: |
| Timon2210 wrote: |
| MrBSI wrote: |
Would love to see a pic of that please,can you do it? |
You cant really see the post cat sensor unless you get the car up on a ramp.
The pre cat sensor is just screwed in to exhaust manifold, then cat in the downpipe then another lambda sensor after the cat.
All the 2nd sensor basically does is check the cat is actually working correctly.
Posted: Sat Mar 02, 2013 3:45 pm |
Well that is my CAT,but i have no 2nd O2 sensor like the one in the diagram,have you used your car VIN on service box or some other car,what I meant is to see how is your CAT is located
Posted: Sat Mar 02, 2013 3:51 pm |
I used my VIN number, my TU3 206 is L4 VEHICLE TECHNICAL DEPOLLUTION according to Service Box.
