Latest: tbafonso
Overall: 17130
Online Now [182]:
Visitors: 181
Today: 21689
Total: 103844002
Forums › The Car › 206 Talk › Manifold Gains on gti 137
Zack
PostPosted: Tue Mar 05, 2013 6:39 am Up
What manifold would be better for my 206 gti 137
180 manifold
or stainless 4 - 1 manifold
or Stainless 4 - 2 - 1 manifold
cheers
PostPosted: Tue Mar 05, 2013 6:45 am Up
4-2-1 but they tend to be long so you'll also need uprated engine mounts to restrict engine movement.
Zack
PostPosted: Tue Mar 05, 2013 6:48 am Up
Im running on group N on bottom engine mount or do you need the lot?
cheers
iainlovatt
PostPosted: Tue Mar 05, 2013 8:46 am Up
i have a 180 one you can have on the cheap!
pm me if you are interested..
(My Garage)
Zack
PostPosted: Tue Mar 05, 2013 12:34 pm Up
Yea but what will the gains be :/
PostPosted: Tue Mar 05, 2013 12:38 pm Up
A single modification on its own will get you next to nothing. You need to fit it with other changes to get the full benefit.
Zack
PostPosted: Tue Mar 05, 2013 12:44 pm Up
Yea but would it still be as good as 4 - 2 - 1? with cat cams
PostPosted: Tue Mar 05, 2013 1:01 pm Up
Which Cat Cams?
Zack
PostPosted: Tue Mar 05, 2013 1:14 pm Up
www.catcams.co.uk/acat...files.html
these any good?
Zack
PostPosted: Wed Mar 06, 2013 2:08 pm Up
any one?
usher
PostPosted: Thu Mar 07, 2013 1:54 am Up
rattles down to cost really
180 mani will be less than 100 quid and easyer to fit, might need to change gear linkage slightly not sure
rraceland 4-1 less than 200 quid more noticable gains than the 180 but needs engine dropping a few inch or sub frame removing and some custom work to fit the cat back
the 4-2-1 is over 500 quid and as wdward says will require all engine mounts upgrading and the same work as the 4-1 but the gains will be better
as for the cams i dont think you get alot from them alone you need more head work to get the most out of them and for over 1500 quid for 15-25 bhp max
i got 10bhp from a piper reprofile and that was a cheaper option but still cost near 1000 re profile
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Thu Mar 07, 2013 3:45 am Up
So for a quick and easy gain 180 manifold. would it sound different?
With them cams do you need re mapp of any thing?
Thanks Smile
usher
PostPosted: Thu Mar 07, 2013 5:07 am Up
with any cams you need a re-map
180 manifold might give you something but doubtfull, raceland is good for midrange torque cant coment on the 4-2-1
i would say you will gain 10 from the map 5 from cams and 5 from manifold max but you wont see them gains indevidually you will need the mapto get the max out of all of them
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Thu Mar 07, 2013 5:26 am Up
Not a bad gain tho id be happy with 13 from all that.
At the min im running just a de cat.
Plan is to get a K&N Typhoon Induction Kits, The Cams you said, 180 Manifold, And Then Remap it all.
What BHP you running?
cheers
PostPosted: Thu Mar 07, 2013 5:56 am Up
You have to change to the dog w**k 180 cable setup the 138 rod setup will not clear the 180 exhaust manifold.
