![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › Rain sensor missing |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Fri Mar 08, 2013 4:08 pm |
Hi guys, I've recently descoverd that the rain sensor has been removed from my 2001 gti, there are 2 wires tucked behind the cover where the preveous owner has cut the sensor off for whatever reason
would it be as simple as buying a working sensor and conecting the wires to get the auto setting on the wipers to work
Any info would be great, cheers
| | ![](images/spacer.gif) |
Posted: Fri Mar 08, 2013 4:54 pm |
If you have a pre-plex GTi then I have a working sensor and can supply a piece of loom to attach it to.
Posted: Sat Mar 09, 2013 4:10 am |
Has it had a new windscreen?
Posted: Sat Mar 09, 2013 5:20 am |
I'm not to sure if it's pre-plex, how would I find out ?? And yes its had a new screen
Posted: Sat Mar 09, 2013 5:49 am |
If the stereo remote stalk is a long stick it's not multiplexed. If it's a fat chunky thing with buttons on it the car is multiplexed.
Posted: Sat Mar 09, 2013 11:38 am |
It has the longer stalk so.it would be pre plex in that case
| ![](themes/base/images/forums/otr.gif) |
