Latest: sparrowdclxvi
Overall: 17139
Online Now [69]:
Visitors: 68
Today: 22649
Total: 112535268
Forums › The Car › 206 Problems › Rain sensor missing
Rain sensor missing
Rhys249
PostPosted: Fri Mar 08, 2013 5:08 pm Up
Hi guys, I've recently descoverd that the rain sensor has been removed from my 2001 gti, there are 2 wires tucked behind the cover where the preveous owner has cut the sensor off for whatever reason
would it be as simple as buying a working sensor and conecting the wires to get the auto setting on the wipers to work
Any info would be great, cheers
PostPosted: Fri Mar 08, 2013 5:54 pm Up
If you have a pre-plex GTi then I have a working sensor and can supply a piece of loom to attach it to.
PostPosted: Sat Mar 09, 2013 5:10 am Up
Has it had a new windscreen?
Rhys249
PostPosted: Sat Mar 09, 2013 6:20 am Up
I'm not to sure if it's pre-plex, how would I find out ?? And yes its had a new screen
PostPosted: Sat Mar 09, 2013 6:49 am Up
If the stereo remote stalk is a long stick it's not multiplexed. If it's a fat chunky thing with buttons on it the car is multiplexed.
Rhys249
PostPosted: Sat Mar 09, 2013 12:38 pm Up
It has the longer stalk so.it would be pre plex in that case
