Latest: S2cgm
Overall: 17178
Online Now [86]:
Visitors: 84
Bots: 2
Today: 10632
Total: 135577313
Project sleeper
Go to page Previous  1, 2, 3 ... 21, 22, 23 ... 85, 86, 87  Next
Ape
PostPosted: Wed Mar 24, 2010 1:44 pm Up
MattieĀ® wrote:
Seb wrote:
Besides, turbo's are for show offs who like whoosh whoosh noises. /end thread Razz
Cool Razz
Something you'd expect a whiner boy to say Laughing
Seb
PostPosted: Wed Mar 24, 2010 1:51 pm Up
Staff - Seb
AHA no.
PostPosted: Thu Mar 25, 2010 2:38 am Up
Been thinking if I'd have to do this job again I'd definately not have gone for these cams. I'd have stuck with the standard exhaust cam and the Piper inlet cam.
That would have saved about £1k too.
What use on a road car is peak torque at over 6k rpm? Even then it's less than 170lb ft.
The car might be faster overall than standard but that's just because it continues to make power where the previously power would drop off. Acceleration might be stronger but it's no night and day difference, it just continues further up the rev range.
Quarmbo
PostPosted: Thu Mar 25, 2010 3:15 am Up
Is there anything you can do to adjust the peak power band? Weren't you thinking of adjusting something?
Ford SportGay-A
gti180boy
PostPosted: Thu Mar 25, 2010 3:23 am Up
you could play around with the timing with the verniers to get the power band kicks in @ lower revs
180 Doctor
macj
PostPosted: Thu Mar 25, 2010 1:50 pm Up
would need another RR sessioon to map a new fuelling curve if you mess with the cam timing Crying or Very sad
PostPosted: Thu Mar 25, 2010 3:39 pm Up
I guess if any re-mapping is needed a total map from scratch would be needed as well.
Quarmbo
But like you said, the ECU would be locked now? So would have to go back to Ecosse? In Scotland. Bummer.
Ford SportGay-A
vanman_foci
PostPosted: Thu Mar 25, 2010 3:46 pm Up
could you just try to access the map? Obviously from there if it's locked/unlocked then you know a bit more what you need to do.
macj
PostPosted: Thu Mar 25, 2010 3:49 pm Up
Ecosse will tell you if it is locked... they should let you unlock it as you own it and paid for the map it contains... also the map is useless to anyone else unless they have exactly the same mods. they could use it as a base map though
PostPosted: Fri Mar 26, 2010 11:27 am Up
Took the car home through the scenic route today...it does go quite nicely and it does make a nice sound, you can't go fast discretely though...
It is a bit unruly for everyday use but it is fun once it has some revs on the engine. It's quite good fun and I actually like it again. I do think for sustained hard use an oil cooler would be a wise move. It does run hotter than it did before.
I'm still buying another car though!
spike_202
PostPosted: Fri Mar 26, 2010 11:40 am Up
I totally agree with you ed its hard to give it some without looking/sounding to suspicious haha.
what are you thinking of as a daily driver then??
**spike's project**
TEAM:+200bhp
PostPosted: Fri Mar 26, 2010 11:43 am Up
I really liked the Jetta hire car I had so going for one of them. Got to be the right spec though...
PostPosted: Fri Mar 26, 2010 11:44 am Up
Glad you like it again Smile
Quarmbo
PostPosted: Fri Mar 26, 2010 1:25 pm Up
Positive news, glad you enjoyed the drive!
Ford SportGay-A
Page 22 of 87
