Forums › The Car › 206 Talk › TOP MOUNT BUSH |
Posted: Thu Mar 14, 2013 9:28 am |
just a general question i recently had my MOT done and the garage that did it said the there is wear on the near side top mount bush and that it will be what is causing a knocking sound i am getting how hard is it to change these top mount bushes ??
Posted: Thu Mar 14, 2013 11:42 am |
SORRY JUST TO ADD THE FRONT TOP MOUNT BUSH
Posted: Thu Mar 14, 2013 12:37 pm |
You just remove the strut and take the mount off with the bearing...need spring compressors too.
Posted: Thu Mar 14, 2013 12:55 pm |
ok cheers quite simple then
Posted: Thu Mar 14, 2013 1:25 pm |
Not really! Easy when you know but be difficult if you don't have the right tools.
Posted: Thu Mar 14, 2013 3:45 pm |
Easy job tbh but spring compressor is a must unless you want a compressed spring in your face ;( ..
Posted: Thu Mar 14, 2013 4:49 pm |
Haha yep just bin and got some of a friend
