Online Now [214]:
Visitors: 213
Today: 128837
Total: 105705718
Forums › The Car › 206 Problems › Issue trying to start the car
EioPago
PostPosted: Mon Mar 25, 2013 3:55 pm Up
Hello everyone,
sadly my 1st post here is about a problem rather than an appreciation.
Here is the issue:
When I turn the key the lights on the dashboard come on as normal but is sounds like there is no attempt to start the engine.
I realized the clock was reset.
The air conditioner does not work but everything else does, side lights, fog lights.
Could this be a flat battery?
If it is likely to be, which one would I need?
the exact model is 206, 1.4, 16v petrol (2005)- Sport
Please advise.
thank you.
ARRAN
PostPosted: Mon Mar 25, 2013 5:16 pm Up
Faulty battery or maybe a bad earth strap.
See my project here.
PostPosted: Tue Mar 26, 2013 3:07 am Up
Air con won't work without engine running. Sounds like a flat battery.
PostPosted: Tue Mar 26, 2013 3:10 am Up
Could be a flat battery due to a dead or dying alternator. Get the charging circuit tested before splashing out on anything.
Tolkienfan001
PostPosted: Tue Mar 26, 2013 4:10 am Up
Trade Rating: +13
Same car as me Smile 3 or 5 door? Colour? Have you sorted your starting problem?
2005 1.4 16v Sport
Check out my 206 here!
EioPago
PostPosted: Tue Mar 26, 2013 2:22 pm Up
It`s blue, 5 doors.
Anyway, I will try a new battery tomorrow and take it from there. My main worry is if the alternator is faulty.
I'll let you know.
Thanks!
PostPosted: Tue Mar 26, 2013 2:51 pm Up
EioPago wrote:
It`s blue, 5 doors.
I'll let you know.
Thanks!
So why not get it tested first?
