Online Now [279]:
Visitors: 278
Today: 9091
Total: 106054955
Forums › The Car › 206 Problems › 206 rear knocking help plz
nmcc
PostPosted: Mon Mar 25, 2013 6:44 pm Up
My 1999 1.4 petrol pug 206 is making a very loud knocking noise from the rear passenger side when i go over bumps, help?
you can hear the knocking noise even if you stand outside and shake the car from side to side, what could this be? any hep appreciated
ive checked the shocks and mounts nothing has any play, could it be the trailing arm bearing, the wheels has no play in it either. and the exhaust isnt banging either...
usher
PostPosted: Tue Mar 26, 2013 2:52 am Up
check the arb that can knock sometimes if it is i have herd you need to hit it at each side at the same time to tighten it in the end plates
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Uz
PostPosted: Tue Mar 26, 2013 4:01 am Up
Itll be your shocks or arb... with it knocking when you shake the arb itll probably be the arb.
I had it on the shocks I fitted on the XSi. Due to how low the car was, over bumpy ground the shocks would max out.
