Forums › The Car › 206 Problems › 206 2003 front wash/wiper relay? |
Posted: Mon Apr 01, 2013 11:20 am |
Hi Forum,
I have a problem with my daughter's 206 2.0HDi which is driving me crazy, and I'd be very grateful for any advice.
I was changing the whole front wiper linkage/motor assembly due to snapped connector. With new one loosely in position I tried the new wiper to check it was a working unit. As it turned a screwdriver slipped down in the mechanism and it stopped, only for a split second as it was then turned off.
Now we have no wiper or washer (which was fine)(rear wash/wipe still good).
Have checked all the fuses I can find, and I've put live into the wiper motor and it turns. Have put live into connection on engine-bay fuse box and is showing a short, but when put into the same connection while unplugged the wiper turns.
I'm coming to the opinion it's one of the relays on that PCB, and would be very please if anybody could point me in the direction of the correct one.
Thanks a lot in advance,
Mike.
Posted: Mon Apr 01, 2013 11:53 pm |
If a relay ID or change not feasible, would a BSI reboot do any good (or harm)?
