Latest: Puggingalong
Overall: 17129
Online Now [290]:
Visitors: 289
Today: 2206
Total: 101042079
Forums › The Car › 206 Talk › Advice on sparkplugs
ruby_the_206
PostPosted: Wed Mar 27, 2013 1:53 pm Up
Hi im wanting to get new spark plugs for my car. I know that I should only get bosch plugs but can anyone tell me whats the difference between normal bosch plugs and super bosch plugs and will they make a difference I have a 1.4
Ruby
PostPosted: Wed Mar 27, 2013 1:57 pm Up
Bosch Super Plus will be fine for a 1.4.
Super 4 just give a longer service life.
Tolkienfan001
PostPosted: Wed Mar 27, 2013 2:02 pm Up
Trade Rating: +13
I have just fitted these to my 1.4 16v. All good so far!
2005 1.4 16v Sport
Check out my 206 here!
ruby_the_206
PostPosted: Wed Mar 27, 2013 2:04 pm Up
Brill il get them then thanks also does anyone know an estimate for fitting spark plugs these days?
Ruby
PostPosted: Wed Mar 27, 2013 2:17 pm Up
about 10-15mins it took me. Just take your time and do it properly. special care to screw it in place without forcing it else you'll ruin the threading.
Tolkienfan001
PostPosted: Wed Mar 27, 2013 2:18 pm Up
Trade Rating: +13
Buy them online and fit yourself. Took me 10 minutes. It's really easy all you do is remove the engine cover coil pack then plugs.
You will be glad you did it!
2005 1.4 16v Sport
PostPosted: Wed Mar 27, 2013 2:20 pm Up
I fitted Super 4's last time, I wont bother again, ill go back to the Super Plus at next service.
If your diy fitting them, take the ratchet of the extension + spark plug socket & spin the new spark plugs in using your fingers on the end of the extension to avoid cross threading the plugs, do the final tighten with the ratchet.
ruby_the_206
PostPosted: Wed Mar 27, 2013 2:37 pm Up
Im a women lol no chance im going to do myself!
Ruby
PostPosted: Wed Mar 27, 2013 2:45 pm Up
Its one of the easiest things!!!! It would be quite hard to get these wrong! Even I managed to do it first time okay!!
ruby_the_206
PostPosted: Wed Mar 27, 2013 3:00 pm Up
Ok I might attempt do I need any special tools and do I disconnect battery or anything before? Where are they located?
Ruby
PostPosted: Wed Mar 27, 2013 4:02 pm Up
Will be slightly different if your engine is the 8v, but same principle. Though don't feel pressured to do it lol, If you're not confident 100% then probably best getting someone else to do it. Tbh, garages shouldnt really charge more than 20odd quid.
EDIT: yes for sure battery would need disconnecting and BSI shutdown/restart procedure if your 206 is multiplexed
www.206info.co.uk/Foru...spark.html
KrisB
PostPosted: Wed Mar 27, 2013 5:52 pm Up
Peugeots dont like NGK's. Another vote for bosch.
Also id be carefull buying anything online. Sparkplugs would be easy things to 'Fake', just like Osram nightbreaker bulbs.
French car specialist. West Sussex. www.KrisB.co.uk
SinfulDesignCom
PostPosted: Wed Mar 27, 2013 10:41 pm Up
Don't downplay the "woman" card here Ruby... my ex was a mechanic/welder Laughing
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
