Online Now [570]:
Visitors: 569
Today: 77030
Total: 105803649
Forums › The Car › 206 Problems › Mfd problem
Mfd problem
Stu206gti
PostPosted: Thu Apr 04, 2013 1:47 pm Up
Hi all. hope someone can help me. my ppt30 wasnt working when i got the car. it has no display on it. i changed the bulbs and the bulbs work my a/c display is fully working.Would this mean the display has gone. The car is an Y reg gti 138. cheers
PostPosted: Thu Apr 04, 2013 1:56 pm Up
www.206info.co.uk/Foru...ppt30.html
Stu206gti
PostPosted: Thu Apr 04, 2013 2:02 pm Up
Cheers Dj so am I right in thinking if the bulbs light up this fix will work
PostPosted: Thu Apr 04, 2013 2:05 pm Up
Should do. Once you open it up, youll see if the pin is broken.
Also before you remove it, try pressing down on the display whilst its in the car and see if it gets some life. Would also confirm if its the pin again.
99% of the time, this is the problem anyway. Its a common issue with the ppt30
Stu206gti
PostPosted: Thu Apr 04, 2013 2:14 pm Up
Thanks again Dj I will have a go and let you no the out come
