Online Now [76]:
Visitors: 75
Today: 26564
Total: 105261298
Forums › The Car › 206 Talk › 206 hdi owners ---- favour
Spiky
PostPosted: Thu Apr 11, 2013 12:43 pm Up
Finally got the speedo working on my 206 hdi
But not sure the speedo is correctly showing right speed
Can someone tell me what rev's they are doing in the following examples
4th 30
4th 40
5th 70
206 HDI Dturbo X/2000
PostPosted: Thu Apr 11, 2013 12:51 pm Up
Can someone tell me what speed try are doing in the following example
4th 30
4th 40
5th 70
No point someone else doing it as it will depend on their revs.
If you have something with GPS like a sat nav or iphone, set that up and compare your speed on the dash to the speed displayed on the device.
Another option is to get a friend to follow you at a constant distance and compare the speeds that both cars are showing. Not as accurate as the GPS method, but more accurate than someone saying they are doing 72 in 5th and 53 in 4th.
Spiky
PostPosted: Thu Apr 11, 2013 1:03 pm Up
First post corrected as I meant revs not speed Smile
I've done GPS on phone and speedo is under reading
I'm running 195 50 15's. bit would have thought it would
Make much difference to speedo compared to standard
PostPosted: Thu Apr 11, 2013 1:45 pm Up
How much is it under reading by? The GPS will be more accurate then the speedo and speedos are designed to under read, possibly by as much as 10%
Spiky
PostPosted: Thu Apr 11, 2013 1:46 pm Up
Speedo 27-28. GPS 30
Speedo 65 GPS 70
PostPosted: Thu Apr 11, 2013 1:49 pm Up
I would have expected it to be the other way round speedo 30mph GPS 27mph. Stops the speeding tickets.
At least now someone can compare their speedo to a GPS and see if it's similar results to put your mind at ease.
PostPosted: Sun Apr 14, 2013 8:35 am Up
I never changed to 4th 'till about 50mph.
Spiky
PostPosted: Wed Apr 17, 2013 1:35 pm Up
Fixed this now
I must have used the wrong cog/shaft under the vss
Speed is correct now
