Latest: TigerHunters
Overall: 17144
Online Now [61]:
Visitors: 60
Today: 7864
Total: 115881177
Forums › The Car › 206 Talk › 180 injectors
180 injectors
Zack
PostPosted: Mon Apr 22, 2013 3:43 pm Up
Can i run 180 injectors on my GTI 137 it only has a induction kit and stainless exhaust with decat?
cheers
PostPosted: Mon Apr 22, 2013 3:46 pm Up
No, not unless you have the car remapped. Which it should have been already
PostPosted: Mon Apr 22, 2013 3:47 pm Up
No point when your 138 injectors are plenty adequate enough.
Zack
PostPosted: Mon Apr 22, 2013 3:51 pm Up
Want it to pop and bang a bit. Because my old 206 did.
Zack
PostPosted: Mon Apr 22, 2013 4:05 pm Up
Also if i fitted these and had a remap would be a bhp gain yea?
PostPosted: Mon Apr 22, 2013 4:13 pm Up
You know why cars pop and bang? Probably not why you think they do.
Zack
PostPosted: Mon Apr 22, 2013 4:14 pm Up
To much fuel?
usher
PostPosted: Mon Apr 22, 2013 5:58 pm Up
What bore is your exhaust system
If you get a manifold on there and 2.5in bore it will pop
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Tue Apr 23, 2013 12:54 am Up
Probably, 2 to 5 with the minimal modifications you have done
PostPosted: Tue Apr 23, 2013 1:54 am Up
Zack wrote:
To much fuel?
Nope. When you lift off the throttle the car cuts the fuel mixture so the mix becomes very weak. It’s so weak it goes into the engine and misses the spark plug. That tiny amount of fuel then goes into the exhaust and ignites due to the heat. You can tinker with map settings to adjust the amount of fuel that is put into the engine on the overrun to change the amount of popping!
usher
PostPosted: Tue Apr 23, 2013 2:07 am Up
put the injector in the exhaust with a spark plug problem solved LOL
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Tue Apr 23, 2013 2:51 am Up
Thanks for that ill get a manifold sorted then. Smile
usher
PostPosted: Tue Apr 23, 2013 11:01 am Up
mine used to pop and burble on down changes with just the manifold and de cat with standard system
project thread WIP
garage
FAQ
206 gti firedance
