Online Now [83]:
Visitors: 82
Today: 23713
Total: 105258448
Forums › The Car › 206 Talk › Spring clip connectors
bikesforme
PostPosted: Tue Apr 16, 2013 10:47 am Up
Hi.Does anyone no where i can get the spring clip for the spring clip connectors. Been looking on ebay with no joy.
PostPosted: Tue Apr 16, 2013 12:55 pm Up
What are spring clip connectors? Same as Junior Power Timers?
bikesforme
PostPosted: Tue Apr 16, 2013 1:05 pm Up
The clips that are held together with a u shape spring clip, ie the air con connector. I am after the u shape clip, easy to lose.
PostPosted: Tue Apr 16, 2013 2:04 pm Up
Sounds like you mean Junior Power Times plugs.
bikesforme
PostPosted: Tue Apr 16, 2013 9:01 pm Up
Very Happy Did not no they were called that, just after the spring clip.
PostPosted: Wed Apr 17, 2013 6:08 am Up
Try the Peugeot dealer. The can get just the plugs for the wiring looms. You might not be able to just get the clip on its own though.
