![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › a question about speedo dials |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Thu Apr 25, 2013 5:38 am |
Guys, I would like to know if the white dials in a 206 hdi would be the same as dials from a 206 xsi?
As I am loooking to simply take out the dials from my xsi and put in white dials from a hdi, I wanted to check before I did this to make sure they would be the same or is there something I need to check.
Cheers guys
| | ![](images/spacer.gif) |
Posted: Thu Apr 25, 2013 9:15 am |
Posted: Thu Apr 25, 2013 9:33 am |
Is the xsi A diesel to?
Posted: Thu Apr 25, 2013 11:28 am |
rev counter will look a bit silly with the different rev ranges.
Posted: Thu Apr 25, 2013 2:38 pm |
the rev range will only go up to about 5000rpm (ish) on a diesel rev counter..
| ![](themes/base/images/forums/otr.gif) |
