Online Now [1414]:
Visitors: 1413
Today: 303446
Total: 146434692
Forums › The Car › 206 Problems › 206 sw rear axle
206 sw rear axle
jacksw
PostPosted: Fri Apr 19, 2013 7:15 am Up
Hi, new to the forum, but had my car for a few years. Its a 2.0 hdi sw, just failed it's MOT with a dodgy back axle (had a mystery knocking for a while, no one knew what it was until now). So after a rear axle with drums and abs...hard to find on ebay! Loads without abs! Any advice/parts welcomed!
bugawuga
PostPosted: Fri Apr 19, 2013 7:29 am Up
What exactly is wrong with the axle? The axle is a big old beast.. What was the reason for failure? (You should have an explanation).
Uz
PostPosted: Fri Apr 19, 2013 7:32 am Up
Just buy a GTi180 axle and swap it over... you'll have discs that way and not have to worry about the beam not having abs.
jacksw
PostPosted: Fri Apr 19, 2013 7:35 am Up
Well I was told it was the internals that have gone as there is a lot of play, don't have the certificate right now as am at work, but it does have more detail on there as to the problem. Been told that if I can get one it's an easy job to drop out the old one and pop a new one up as a complete unit, would you agree with that? (I don't know a vast amount on these cars!)
jacksw
PostPosted: Fri Apr 19, 2013 7:36 am Up
How much work is involved with fitting disks instead? I was told if it has abs then I need one with abs, would you disagree wit that Uz?
Lecktorious
Trade Rating: +59
I've got a GTi 180 axle for sale if you need one. Pics are in my FS thread, link is in my signature.
'98 Nile Blue 306 GTi 6
Uz
PostPosted: Fri Apr 19, 2013 7:47 am Up
It's a virtually straight swap mate... never done it on a 206 but I'm sure the same applies as the 106 where you have to change the brakelines an just handbreak cable. Did it on my 106 Quiksilver with a GTi rear beam. But if your cars got ABS than you need an ABS beam due to the trailing arm being different.
jacksw
PostPosted: Fri Apr 19, 2013 7:49 am Up
OK thanks Uz, that seems to tie in with what I'v heard. I'll check out putting disks on with ABS as they seem more common than the drums!
Uz
PostPosted: Fri Apr 19, 2013 8:26 am Up
Only other thing I can suggest is that if you've got a second car, whip your beam off and take it up to imaxles if your local to them. £300 they charge to fully refurb it. May be better than buying a second hand beam that you don't know the history of.
jacksw
PostPosted: Fri Apr 19, 2013 8:29 am Up
Fair enough, I know I can get a refurbished one locally (ish) for around £250, was hoping to get a used one for around the £100 mark lol. I'm tight.
PostPosted: Fri Apr 19, 2013 9:54 am Up
I did a drum to disk conversion on a hdi a couple of months ago. Pretty much as you say really. The hardest part I had was I had to move the compensator valve over as well as I was putting an ABS axle on a non ABS car. Easiest place to swap the brake lines around is at the flexi lines on the axle, as both axles run the same. Then it's just handbrake cables, bleed up the brakes and off you go.
PostPosted: Fri Apr 19, 2013 10:00 am Up
Where are you based?
Abzynthe
PostPosted: Sat Apr 20, 2013 4:19 pm Up
East Area Rep - Abzynthe
I have the 180 axle on my Sw, was a straight swap, only thing needed changing was the handbrake cables Smile
jacksw
PostPosted: Mon Apr 22, 2013 3:47 am Up
Based in Kendal, Cumbria
jacksw
PostPosted: Tue Apr 23, 2013 5:02 am Up
Managed to find an axle with drums and abs, thanks for the advice! Also, any one know if someone has a dropped a 180 engine into an sw? Just a thought.
