Latest: jackrox1992
Overall: 17186
Online Now [352]:
Visitors: 351
Today: 171645
Total: 148537299
Forums › The Car › 206 Problems › which standard cat do i need for 180
19Connor92
PostPosted: Sun Apr 28, 2013 4:18 pm Up
My previous cat had 2 O2 sensors what do i do because i am going to be fitting my janspeed to one of these?
PEU1077H: shows on O2 sensor and says BHP180
PEU1127H: show two O2 sensors but say BHP136
19Connor92
PostPosted: Sun Apr 28, 2013 4:21 pm Up
and the PEU1125H: shows one O2 sensor and says BHP 180.
my peugeot is 2004
PostPosted: Mon Apr 29, 2013 6:32 am Up
Why do you need to change the cat? Do you know how expensive there are from peugeot?!
PostPosted: Mon Apr 29, 2013 7:28 am Up
I'm having to change mine. It's got a hole near where it joins the centre pipe, just about big enough to get my finger tip in, and the weld under the cat has started cracking, and the weld around the Lambda sensor boss has got a small hole. Covered it in exhaust putty, but it's only a bodged temp fix until I get the new one later this week.
ECP do some good prices and have a discount on until tomorrow, although their discounts are a bit like sales at DFS. They always have one.
To the OP, have a look at you existing cat, I'm referring to my 1.4, but it only has one O2 sensor on the pipe which is after the cat. The other sensor is on the manifold.
You could always have a look on service box to see which one it states, and then see if you can cross reference the Peugeot number to the suppliers number.
Big_Rich180
PostPosted: Mon Apr 29, 2013 7:29 am Up
My 180 used to have a sensor in the cat and a sensor on the down pipe, the down pipe and cat are one this on the 180.
19Connor92
PostPosted: Mon Apr 29, 2013 11:35 am Up
been phoning around after work and peugeot say there should be two lambda sensors and the one that is fitted has two. but when i got to onlineautomotive they say there is only one??? what part shall i buy
Lecktorious
PostPosted: Mon Apr 29, 2013 12:20 pm Up
Trade Rating: +59
I would go with what Peugeot are stating. Are you buying the CAT new? As I have a good second hand GTi 180 here.
'98 Nile Blue 306 GTi 6
