Latest: S2cgm
Overall: 17178
Online Now [185]:
Visitors: 183
Bots: 2
Today: 89323
Total: 136301288
Forums › The Car › 206 Problems › wont start
wont start
dobbin
PostPosted: Sun Apr 28, 2013 11:50 am Up
I have just put a clutch in a 206 after putting it back together it run out of diesel put some in but will not start on looking under the bonnet I have a three wire connector plug now not connected it is on the wiring harness
and is near the battery housing and the fly wheel sensor coloured wires are
white green pink.
All it will do now is turn over any help will do thanks
PostPosted: Sun Apr 28, 2013 12:26 pm Up
Could it be air in the fuel lines?
dobbin
PostPosted: Sun Apr 28, 2013 12:33 pm Up
thanks V9977 but there is a manual pump under bonnet which I deployed are you saying that the plug could be there for a different model done OBD2 and no faults have shown up in rac thought about trying to bump if not ringing rac
PostPosted: Sun Apr 28, 2013 1:00 pm Up
Sounds like you've found your problem. Was it definetly connected before?, as the looms are the same on different models so may be a spare for something else.
Has the earth been reconnected on top of the gearbox?
dobbin
PostPosted: Sun Apr 28, 2013 1:06 pm Up
Earth connections intact this three wire socket seems clean inside as though it was previously connected to something but after a thorough inspection cant find anywhere for it but would that not show on OBD2 as fault help appreciated
DREWDEN
PostPosted: Sun Apr 28, 2013 3:20 pm Up
Have you tried slackening fuel injectors one by one whilst cranking engine, so when fuel comes out
tightening them up again.
206 2ltr Hdi glx 53 plate
PostPosted: Sun Apr 28, 2013 3:27 pm Up
Please dont ever let me see you that post that again. The pressure inside the rails is inexcess of 200 bar!
Do you really want to try that?!
What engine is it?
dobbin
PostPosted: Sun Apr 28, 2013 3:50 pm Up
thank s but abit peed off because OBD2 removed flywheel sensor cable and run OBD2 again with it off and it came back no faults that cant be right also it is a 1.9 diesel
PostPosted: Sun Apr 28, 2013 3:55 pm Up
All i can reccomend is check all your wiring and bleed the fuel system by priming it loads with the hand pump
PostPosted: Sun Apr 28, 2013 4:16 pm Up
Not all obd scanners will work with a 206.
