Latest: Stu-mill
Overall: 17131
Online Now [59]:
Visitors: 58
Today: 7806
Total: 104917446
Forums › The Car › 206 Problems › 306 gti-6 inlet on gti
Zack
PostPosted: Thu May 02, 2013 4:22 pm Up
Will a gti-6 in let manifold go on my gti 137 for get about the bolt on part tho?
Cheers
PostPosted: Thu May 02, 2013 5:37 pm Up
No, different shape ports.
Zack
PostPosted: Fri May 03, 2013 1:53 am Up
Are they the same ish distance a part tho?
Zack
PostPosted: Fri May 03, 2013 4:16 am Up
The plan is to get a gti-6 inlet and a 180 inlet cut the plates you bolt on to the engine weld the 180 plate on to gti-6 one jobs a good un.
All I need to no is if all the wires that plug in to my 137 in let will plug into the gti-6 one?
Cheers
PostPosted: Fri May 03, 2013 7:42 am Up
Why not use the 180 manifold? Or would that be just too easy?
Zack
PostPosted: Fri May 03, 2013 7:45 am Up
If you no how to change it to cable?
205GTi180
PostPosted: Fri May 03, 2013 7:52 am Up
Changing from fly-by-wire to a cable throttle is easy. Far easier than cutting and shutting the inlet!
All you need to do is break apart the motor side of the TB and fit/weld a yoke and throttle stop.
205 with Supercharged GTI 180 lump 374 bhp...soon to be 400+
PostPosted: Fri May 03, 2013 8:36 am Up
That or use the body of the d8 v6
Zack
PostPosted: Fri May 03, 2013 8:52 am Up
What and everything ill plug in?
usher
PostPosted: Sat May 04, 2013 6:07 am Up
The gti6 won't fit as its longer than the 180
As mentioned the 180 will fit with the tb mnodded or changed but may as well save up for bodies like i am I was going to get the 180 3yeard ago but nearly 1k with the remap and parts I would rather the 40vhp from tbs than 12 from the 180 mani at half the price of tbs
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Sat May 04, 2013 12:01 pm Up
Where at what bodies u getting?
usher
PostPosted: Sat May 04, 2013 12:37 pm Up
Throttle bodies there a little less than 2k then I'llfit it myself with a base mmap to get it running then head to the mappers but got to pay off my new car first
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Sat May 04, 2013 12:38 pm Up
Sweet sounds lush. Do you no how to wire the new ecu up then?
usher
PostPosted: Sat May 04, 2013 1:14 pm Up
How hard can it be lol
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Sat May 04, 2013 1:15 pm Up
Lol let me know how you get in are you getting kit off pug one off?
