Forums › The Car › 206 Talk › power steering |
Posted: Sat May 04, 2013 12:41 pm |
this is my first gti 138 and the power steering feels quite heavy compared to other cars ive had can anyone give a rough idea on roughly how heavy this should be as ive read that they are a bit heavier for handling purposes ta.
Posted: Sat May 04, 2013 12:43 pm |
The 206 power steering is heavier then Vauxhall / Ford stuff of the same age, its just the way they are.
Posted: Sat May 04, 2013 12:47 pm |
oh okay ta for the rapid response thought i was going to have to start hunting down a fault!
Posted: Sat May 04, 2013 1:14 pm |
yeah they are pretty heavy, if there's no abnormal noises coming from the pump then its fine, just keep an eye on the level tho
Posted: Sat May 04, 2013 4:06 pm |
Electric pump from a Saxo makes the steering a bit lighter...but would also need a few other things changing to fit it.
