Posted: Mon May 06, 2013 3:27 am |
Hi all,
I've recently had my car lowered, front by 30mm & the back was adjusted 1 'notch' on the rear torsion bars (standard shocks), which makes it sit slightly lower than the front.
How can I make the rear sit slightly higher than the front suspension but lower than stock?
Im looking for the rear to sit around 20-25mm lower than stock height. Also would gas rear shocks make any difference?
| | ![](images/spacer.gif) |
Posted: Mon May 06, 2013 5:01 am |
If it was done the notch way, it was don't the crap way. The correct way is to take the torsion bars out, that way you can accurately adjust the height.
Posted: Mon May 06, 2013 5:36 am |
Ah right ok. How do you adjust the correct way? Also is it worth putting gas shocks on?
Posted: Mon May 06, 2013 1:52 pm |
There are plenty of guides on how to lower the 206 rear axle, there's one on here somewhere, or just google it. Yes I would uprate the rear shocks.
Posted: Tue May 07, 2013 3:56 am |
I've found this www.206info.co.uk/Foru...guide.html
Is this the method you were referring too? Mine has already been adjusted the 'crap way' so I just need him to put them back as they were & then adjust using this method? Just out of interest does anybody know the stock height for the rear?
