Latest: Stu-mill
Overall: 17131
Online Now [227]:
Visitors: 226
Today: 68168
Total: 104876996
Forums › The Car › 206 Problems › Ppt 30 not working. Not the usual problem.
206boyracer
PostPosted: Tue May 07, 2013 4:30 am Up
Hi all my PPT30 has stopped displaying the temperature and time/date etc. it illuminates and the bulbs work fine but there are no digits. I have checked the pins inside and they are all solid. Anyone any ideas what could be wrong? I have even bought another second hand and tried it with no joy. Is there a chance a wire could be damaged which carries the data? Anyone know how I could check? Thanks in advance. Dan.
206 GTI 138.
gazza82
PostPosted: Tue May 07, 2013 6:54 am Up
Are you sure that there isn't a dry joint on the two parts of the board?
206boyracer
PostPosted: Tue May 07, 2013 7:56 am Up
The joints looked fine. Il try some wd40 on the main plug on the back later but the pins are ok. As I said its illuminating and dimming as it should just no numbers. It stopped a while ago and then about 2 days later came back then it went again and hasn't come back since.
206 GTI 138.
206boyracer
PostPosted: Wed May 08, 2013 1:18 am Up
Double checked all the connections doesn't seem to be a problem and even checked the pins inside but they are fine. Still no display. Sad anybody have any ideas?
206 GTI 138.
PostPosted: Wed May 08, 2013 2:13 am Up
Don't. WD40 is conductive and you are likely to do more damage. Buy some proper electrical contact cleaner and do the job properly.
WD40 now do a contact cleaner in their specialist range. It's worth buying the right stuff and saving more expense further down the line.
